| | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Hi, I'm new to Stovebolt. I have a 54 Chevy 3100, 235, which has the add on filter near the carb. My question is when changing oil, the 235 takes 5 quarts, do you add 1 quart for the filter? 6 quarts for an oil and filter change. Thanks a bunch, awk | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Welcome to Stovebolt.com, awk,
If you have a 1 qt canister by-pass oil filter, and you change the filter-element and remove all the old oil from the canister, you would an extra quart of oil when you change oil.
5 qts for the engine 1 qt for the 1 qt filter unit
Some people put some oil in the filter canister when they change oil/filter. This results in less delay in the oil feed/pressure when starting the engine after the oil change.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Good information to know.... John | | |
