Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (Charles in CA, baldeagle, Bill Marlow, Otto Skorzeny, EchoBravoSierra, Jon G, Jeff Ogden, 1 invisible), 45 guests, and 2 robots.
Topics128,005
Posts1,055,266
Members48,418
#958912 07/25/2013 5:05 PM
SOmeone said this is a 1953 chevy motor - but the serial number is not making sense.
F115A
To me it is a 1957 Made in Flint Jan 15 A= std 235
Does this stamp look authentic?
Engine Ser num pic
53Cowboy #958913 07/25/2013 5:11 PM
looks like "eye eye" to me, not "one one", maybe a reman number
53Cowboy #958914 07/25/2013 5:19 PM
The casting date barely visible in the pic looks like a 9, that would make it 1959.
Can you show more of the side of the engine?
My Blog
53Cowboy #958919 07/25/2013 5:49 PM
I looked and to me it says F I I 5 A. With the " I I ". Being I as in Illinois.
1966 Chevy C 30 1 ton truck
53Cowboy #958922 07/25/2013 5:57 PM
It's not unusual to find "I" and "1" used interchangeably in engine serial numbers. Generally, unless otherwise noted, if you see an "I" in an automotive serial number, it is considered a "1". Same goes for "O" and "0".
The code you have posted can be read two different ways, depending on what the casting date next to the starter is. If it is a '57, as you have originally suspected, it is a Flint built Passenger 235. assembled on Jan. 15. But if it's a '59, as Dave suspects, and I agree with from what I see, the number works out as the same plant/application, but the date assembled could be May 11, as '58-'62 went with a day/month format instead of the month/day format found on the earlier engines.
Bill Burmeister
53Cowboy #958933 07/25/2013 6:35 PM
Gonna take it as a freebie and see if it is rebuildable. hopefully it is a full pressure oiler.
53Cowboy #958945 07/25/2013 7:28 PM
'54 and later will be full pressure, so that will not be an issue.
Bill Burmeister
