Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (carbking, baldeagle, NJC), 35 guests, and 2 robots.
Topics128,005
Posts1,055,254
Members48,418
#958527 07/23/2013 8:02 PM
I want to change the rear spring shackles on my 1955.1 Model 3100. I have checked the owners manual and the shop manual but cannot find anything about appropriate jacking points. I assume I need to jack the rear axle and then put jack stands somewhere under the frame, but where? Just behind the spring shackles? In front of the rear spring? Someplace else?
Trooper Jeff
Trooper Jeff
If I can't drive my truck, fetch my horse
"Courage is saddling up even though you are scared to death" - John Wayne
these ol trucks aren't like modern unibodies that need jacking in special places - block the front wheels, jack it up by the rear frame until the weight is just off the spring/axle assembly and put stands/blocks under the frame anyplace out of your way for working on the springs - you want the weight off the springs 'both directions', and the rear tires supporting the axle weight
What does the weight off the springs in BOTH directions mean?
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
means no force on them from above or below, as if they were already off the truck, the arch will be exerting some pressure on the mounting ends, you don't want to add to that
I've always jacked up by the pumpkin, put jackstands under the frame ( usually forward of the work area ) and drop the jack until all weight is off the axle.
MNSmith #958713 07/24/2013 3:48 PM
That is why there are alot of bent rear axle housings in that area.
Always best to jack one side at a time at the spring mount points.
Jacking up by the pumpkin does not bend axle housings. Jacking up incorrectly by the pumpkin could, however. What I mean is making sure they're jacking in the right spot and that the jack doesn't slip or anything.
My 46 GMC on Photobucket
All depends on the axle.
I've never seen an axle bend from being lifted by the pumpkin.
Bill Burmeister
Me either.
Brian
1955.2 3100 Truck
only if done incorrectly, there are different types of "UP"
I've seen the mid 80's, early 90's GM 1 ton axles, the ones with the pressed tubes, leak. At the center section.
I thought the thread was about a 55 Advance Design, wheel to wheel axle housing, no cheesy tubes wink
Thanks, Bill
I was waiting to hear from someone with a bent 1955-1st (or 47-54, too) axle housing.
