2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#958633 07/24/2013 7:40 AM
Does anybody know approximatly how long it shoud take for the heat riser flap to move after startup? I have a new bi-metal spring and the flapper does not bind but it appears to remain in the horizontal position even after reaching full water temp.
neswes #958635 07/24/2013 8:06 AM
after it warms pull up on the throttle rod at the carb while watching it.
neswes #958670 07/24/2013 10:57 AM
Mine had too much tension on the spring and wouldn't open at all. I bent the end tab slightly to give it less tension and now it opens fully after about 10 minutes with the engine running and stays open until the engine cools down. It then closes.
1939 Chevrolet Stake Truck
neswes #973743 09/23/2013 3:24 AM
My valve is moving well.
But it will not stay open even when really warm.
When I pull the throttle I can see it opens but then it closes again. Bad spring ?
I have a new spring so I think I will change it.
Just have to be careful not braking the clamps holding the spring and then remember the position so it points the correct way.
1/2 of a turn to tighten the spring as I remember?
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
