| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95855 06/06/2006 7:27 PM | Joined: Mar 2006 Posts: 18 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 18 | Where is the switch for the brake lights located on a 55 Chevy pickup (series 1)?? | | |
#95856 06/06/2006 7:40 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Pressure activated switch on hydraulic line near master cylinder? | | |
#95857 06/06/2006 7:57 PM | Joined: Mar 2006 Posts: 18 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 18 | I did check around the master cylinder and didn't find what I was looking for. I'll look again to make sure...
Thanks | | |
#95858 06/07/2006 12:10 AM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | i have the same year truck. the brake light switch is located on the firewall close to the footboard bend, between the brake and clutch arms. it is a small oval box with a metal arm against the brake arm. look down and peek around the steering mast and you will see it. good luck.
our garage is a non-profit organization
#95859 06/07/2006 2:00 PM | Joined: Mar 2006 Posts: 18 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 18 | Exactly right! I found it.
Thanks! | | |
