6 members (68ironhead, mick53, Joe H, 5 Window 9434, greenie-reddy, moparguy), 108 guests, and 2 robots.
Topics128,056
Posts1,055,798
Where is the switch for the brake lights located on a 55 Chevy pickup (series 1)??
Pressure activated switch on hydraulic line near master cylinder?
I did check around the master cylinder and didn't find what I was looking for. I'll look again to make sure...
i have the same year truck. the brake light switch is located on the firewall close to the footboard bend, between the brake and clutch arms. it is a small oval box with a metal arm against the brake arm. look down and peek around the steering mast and you will see it. good luck.
our garage is a non-profit organization
Exactly right! I found it.
Thanks!
