1 members (sron48),
124
Mod | | | Forums66 Topics128,164 Posts1,056,966 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 75 | Well I have all 4 bolts out. It rocks , slides back and forth ,but something is holding it from coming out and I'm guessing it's the cable???? But not sure .Anyone know what I can do next . I'm afraid to undu the cable ,might never get it back the right way. Any Idea's???? Thanks jer3545
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | There are 8 nuts you have to remove 4 in the rear near the gas tank ...pic... ...pic... And 4 in the front of the seat riser. ...pic... You do not have to separate the frame to get it out of the truck | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If you are just looking to pull the frame there is a bolt holding it on all four corners to the track. If you look in the small hole where the cable attaches to the track you need to remove those as well (one on each side). That should be it. Once the frame is out you can remove the tracks as described in the previous posts.
| | | | | Joined: Dec 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 75 | Brad thanks I appreciate you.
| | | | | Joined: Dec 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 75 | jer3545 says thanks for all the great response on getting my seat out. I am a newbe .I have been here for several months but lost my password until last night and my old brain kicked in and whala! I have a 49 chevy farm truck with a 9ft bed .Its in great shape .I am working on getting it to run .I installed new plugs , rad. hoses, carb. and fuel pump . I have had bad gas ,along with crud in the bottom of the tank so I am removing the gas tank to clean it out .Then I will put good gas in it with a pre fuel pump filter and see If it will then start. It had run real good two years ago. It has a 54 chevy 6 . So that's my story for now. | | | | | Joined: Oct 2009 Posts: 8 New Guy | | New Guy Joined: Oct 2009 Posts: 8 | Thanks! Again and again you guys save me from pulling my hair out!
Steve 49' 3100 5-Window
