1 members (baldeagle),
86
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 21 New Guy | | New Guy Joined: Apr 2013 Posts: 21 | How hard is it to rebuild front shocks on 1/2 ton pick ups ? Or am I better off buying rebuilt and sending back the cores ? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I bought several cores on ebay. I was unable to press out the shaft. Every way I tried it broke the cast iron. It is easy to clean them you just can't replace the shaft seal. It might be possible if you grind the weld to shaft off. I did not have an acetylene torch. If you used one you would have to replace the seal. Its a custom seal but you might find something that would work. Lever action shocks. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Unless you're wanting to have an original suspension I'd recommend converting to tube shocks. I converted my '38 coupe and love the improvement. There are a couple of rebuilders that can rebuild your lever action shocks. Apple Five Points
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I considered rebuilding and after reading about and talking to others about their experiences and results decided my time and effort would not be worth the cost difference. I bought rebuilt replacements. | | |
