7 members (Hanks custodian, 2-Ton, TUTS 59, Otto Skorzeny, festerhairball, HandyAndy, dt235sd),
83
Mod | | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95804 06/02/2006 8:29 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | I started my truck up for the first time in two years last week. (Yeah!) The resto is heading towards the finish line. It is all new and I have upgraded to an alternator. I have not put the wiring harness in as I still need to paint interior. Can the alternator be harmed by running it without being wired up to anything? Thanks in advance for any answers. Steve O | | |
#95805 06/02/2006 9:35 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Not if it,s used just a little. The current going through the brushes gives off a small amount of gas which acts like a lubricant. The brushes will wear out sooner but if just moved around a bit will not be noticable. A gen . is a different story. If the reg. goes bad & you keep driveing the gen. won,t last very long. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95806 06/03/2006 1:34 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | An alternator shouldn't make any current if it isn't hooked up. They requir some current to create the magnetic field, thats why an alternator can't recharge a completely dead battery. I would be more concerned about running the battery down than damaging the alernator. I would still avoid running it until you can hook up the wireing.
Bill Burmeister | | |
