0 members (),
81
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | When did Chevrolet start using clutch head screws on cars and trucks and when did they stop?
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | When I tried to buy clutch head screw drivers at O'Rielly, I was told I was an idiot for using trailer home screws on a classic. Bought my drivers at Napa  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 30's to the 60's GM used clutch screws, apparently primarily on the trucks Bill | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | twotone, My experience with O'Reillys is, they have never seen a distributor, ignition points or a carburetor. (Ask them for a dashpot!) How could they know about GM clutch head fasteners???? I did learn something today; I did not know clutch heads were common on mobile homes!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | FYI clutch heads were used on trailers and campers through the '90s. RV dealers are a great place to get screwdrivers and bits for clutch heads. Not a good place to find replacement screws since they are all sheet metal type. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | 30's to the 60's GM used clutch screws, apparently primarily on the trucks Bill I've never seen them on Canadian trucks. Do they have them out your way Bill?
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not on CDN trucks Curt, but then the US trucks didn't have any Robertson screws either  Bill | | |
