0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 17 New Guy | | New Guy Joined: May 2013 Posts: 17 | Will a 216 intake/exhaust manifold work on a 235 block? The exhaust ports seem to match to the block but the intake ports are smaller. Using 216 aligning sleeves allows the intake to bolt on, but will it leak? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | There are also machined adapter sleeves available. The can be used 216 to 235 or the reverse. I've seen some on EBay and on the Inliners web site cncdude makes them.
Drew
| | | | | Joined: May 2013 Posts: 17 New Guy | | New Guy Joined: May 2013 Posts: 17 | Thanks for the info on manifolds adapters. Tried Larrows and Sons, but they must be out of business. Phone is disconnected. Will keep looking around for someone who makes the adapter or go with straight 235 pieces and sell my 216 offy 2 barrel manifold. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I purchased a set of port adapters off eBay from seller marshall6831 They are not listed now, maybe you can send him a message if your a member of eBay ...click... If you do get a set I recommend measuring them. I had to dress mine down as they were just a bit to thick. On another note my truck did not use any port rings probably from 1973 to 2010. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | marshall6831 is the previously mentioned by me, cncdude over on inliners. He is the moderator of www.hotrodinlines.com also.
Drew
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Had an interesting experience yesterday when a rat rod powered by a I-250 pulled up beside me at a traffic light. I hollered over at the guy and he said it was turbo'd. Had an auto tranny and ran strong on take off. I always get a kick out of seeing folks use a GM inline in anything. (or F*&d or Chrysler or even a Hercules or Hudson) Just love Inliners.
