8 members (Gib70, 52Carl, Otto Skorzeny, Rusty Heaps, joe apple, 55shaker, Gray_Ghost, Hush), 147 guests, and 0 robots.
Topics128,108
Posts1,056,238
Members48,437
U
U Offline
Is the dark gray on the steering column the same paint that is used on the top dash? See pictures of truck as it is, untouched from factory.
Thanks, Joe
Steering 1
Steering 2
you mean mostly untouched wink the dash top is slightly darker and purposely flattened to reduce glare, the column is the same as the rest of the gray inside, except the floor - the lighter is called marble gray, the darker is Charcoal ... don't know of any modern codes to match them
U
U Offline
Yes Bill, more accurately it is mostly untouched. I was speaking of the darker gray on the top. Well it is VERY touched, just not a complete repaint. wink
The light gray - Marble - on the lower portion I plan to get from Jim Carter. I was also thinking about his rattle can dark gray for the top, as it is supposed to be a splatter finish. So is the column, that is dark gray also, the same Charcoal as the top dash but not flatten?
Thanks, Joe
I haven't seen any proof of the dash top color, but I don't think the flattening alone would account for it looking darker than the other Charcoal areas, compare to the floor ... I'd be inclined to take a sample [like the e-brake handle] to a store and get it matched and add some flattening agent to it for the top
When you figure out the correct paint please let us know.
They talk about charcoal gray here
http://59apache.com/comanche.html
Originally Posted by Truckrolet
(...) They talk about charcoal gray here http://59apache.com/comanche.html
too bad he didn't follow up with posting the code for the Charcoal, looks real close ohwell
Yeah even the commanchi gold is close. The problem with carter is you don't know what to use with the paint. They have no data sheets with it.
U
U Offline
It seems the paint shop mentioned in the link is no longer in that area or more likely has closed. I set an email to Jim Karras, who is listed on the link as a contact. Will let you know if anything comes out of it. Also, contact Bob Adler (shop in NY) and he was kind enough to send me a lot of info from his database but he too states he does not have an answer for the dark Charcoal.
U
U Offline
Jim Karras sent a copy of the factory color chip sheet for 1959 trucks. It lists DUCO 73605 as the interior Charcoal. I have seen this mentioned elsewhere but I think the problem has been that its actual 'recipe' is not known. Will try to follow up on this with paint shop around here.
Is there a way to attach files such as Jim's PDF chart or Bob's Excel shet of his database?
If DUCO 73605 is the code, this thread gives additional code:
Charcoal - DUCO 73605 (Dupont DS174)
Silver Metallic - DUCO MM313 (Dupont 94162)
The Ditzler (PPG) code that matches the above code is shown on this page.
You can call the PPG Color Library to see if they have an original formula, or an "offset formula" (for a matching color), or a modern formula from on original paint chip. 1-800-647-6050 might still be the Color Library phone number. If LonnieC sees this post, he might have a PPG phone number that recently worked for him.
U
U Offline
Some additional clues:
TCP Global, Ditzler DL-31557, 1957 Interior
Dupont History Site, DUCO 73605, 1957 Interior Chip
Dupont History Site, DUCO 73605, 1959 Interior Chip
Dupont History Site, 1956 Truck Interior Text
Dupont History Site, 1957 Truck Interior Text
Dupont History Site, 1958 Truck Interior Text
Dupont History Site, 1959 Truck Interior Text
DUCO 73605 was said to cross over to Dupont DS174 - but one onwer tried it and said it was too light Dupont DS174
Have send request to TCP Global for their insight to this question. Will post answer if I get one.
Thanks, Joe
Joe, a lot of us here have those color sheets in hand as well as on the computer, and as much as it's been cussed and discussed here for ages, no one has come up with a good modern number for those old numbers ... and yes, that DS174 is too light .... need to get a good paint supply store to do color matching on a good original piece and experiment from there - from the look of your truck you have a good sample of both shades
U
U Offline
Yes, the steering support would be a good piece to get to a shop that has a good matching system. I am trying to get the shop owner to do this. Problem is he is in CA and I am in PA. But if I do get him to do this and it turns out well, I will be sure to get the info we need to replicate.
U
U Offline
Well some potentially good news on the mysterious Charcoal gray. I have been working with Jim Wells at TCP Global in San Diego. I was surprised to find that with the room full of color charts back to horse carriage days, they did not have this color ready to go. I sent him the shift rod that was in very good shape color wise. They have used it to create the Charcoal and the paint and parts are on the way back to the shop. When it goes on I will get the shop to tell me how well it did and hopefully they can take a pix (remember, I'm in PA and the truck is in CA smile
I will post the results and if it turns out well, the details.
Moderated by  ndkid275, Phak1
