| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | The lower front of the cab, under where the fender covers it, on both sides is rusted thru. Does anyone make a repair panel for these, if not what is the best way to deal with this? Im sure this is quite common by the looks of it. Thanks Scott
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | After much searching I discovered that I was not using the correct nomenclature, and the hand drawn pictures in my Jim Carter catalog did not depict them well enough. The pieces that I need are called, lower cowl repair panels. Wheelwright Restorations makes them, and Jim Carter sells them. I hope this information is helpful to anyone needing to deal with this problem, and am suprised that nobody responded to this post, as I am sure that this is a common problem. Thanks, Scott | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Hey wanderinwillys, thanks for posting this. I too need these for my '40. Jim Carter shows them for 41-46 only. I guess I'll call them and see if they fit the '40 too. Seems like they would.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | You can call him direct at 413-477-6467. I think you are correct about them being the same. Scott | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks, I'll give him a call. Still have a bit more teardown so I'll do that first in case I find some other surprises.
Dennis
40 Chevy 1/2 ton
