2 members (greenie-reddy, KEVINSKI), 116 guests, and 6 robots.
Topics128,266
Posts1,058,367
Members48,485
#953504 06/29/2013 4:37 PM
The lower front of the cab, under where the fender covers it, on both sides is rusted thru. Does anyone make a repair panel for these, if not what is the best way to deal with this? Im sure this is quite common by the looks of it. Thanks Scott
After much searching I discovered that I was not using the correct nomenclature, and the hand drawn pictures in my Jim Carter catalog did not depict them well enough. The pieces that I need are called, lower cowl repair panels. Wheelwright Restorations makes them, and Jim Carter sells them. I hope this information is helpful to anyone needing to deal with this problem, and am suprised that nobody responded to this post, as I am sure that this is a common problem. Thanks, Scott
Hey wanderinwillys, thanks for posting this. I too need these for my '40. Jim Carter shows them for 41-46 only. I guess I'll call them and see if they fit the '40 too. Seems like they would.
Dennis
40 Chevy 1/2 ton
You can call him direct at 413-477-6467. I think you are correct about them being the same. Scott
Thanks, I'll give him a call. Still have a bit more teardown so I'll do that first in case I find some other surprises.
Dennis
40 Chevy 1/2 ton
