6 members (GRNHydra, Maybellene, 6inarow, fonz8261, greenie-reddy, 1 invisible), 140 guests, and 1 robot.
Topics128,035
Posts1,055,549
Members48,425
#957126 07/17/2013 11:03 PM
Ok, have a 59 1/2 toon with a 235, I have no experience with cars so I have some dumb questions. I'm in the process of installing an hei distributor that I got from Langdon's stovebolt, the instructions tell me to set cylinder #1 to 10-18 degrees btdc, there are a few marks on the fly wheel, a circle(not a bb) which Is tdc, right before the circle the are two vertical lines an inch or so apart, then a triangle a few inches before the lines. where exactly is 10-18 degrees, and what are these marks on the fly wheel?
jesus209 #957129 07/17/2013 11:09 PM
In order to know the meaning of those marks, you need to know the year/engine that the flywheel came out of.
Presumably, it is a 1959 235 truck engine? The timing mark that year is the ball on the flywheel - 5 degrees BTDC - Before Top Dead Center).
jesus209 #957138 07/17/2013 11:43 PM
I'll take a look at it againg tomorow, it also says to run a 10 ga wire from the ignition coil to the ignition switch and delete any resistors, there is a ballast resistor on the fire wall, both wires go to the ignition, is this the resistor Its telling me to delete? do I just pull the wires off of the resistor and tape them off?
