3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | My 1946 Burb has 4 side windows with no metal trim like the cab doors have.
I need to shave the glass about 1/16 to 1/8 inch in order for it to move smoothly up and down in the new window channels and wood frames.
Can anybody suggest a process to do it? I am thinking using a belt sander with a fine sanding belt.
Am I on the right track? The amount I need to remove is too small to use a glass cutter.
Any help or suggestions are appreciated. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | a wet belt sander or go to an old glass shop and have them do it on theirs | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Out of curiosity, why a wet one?
Thank you! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | because it is so hard glass is only sanded wet, lubes the cut and prevents heating and chipping ... use carborundum closed coat wet n dry paper [or a diamond grit wheel]
Bill | | |
