3 members (Pete1946, Steelonsteel, Otto Skorzeny), 239 guests, and 16 robots.
Topics128,077
Posts1,056,032
Members48,433
#956515 07/15/2013 10:45 AM
Hi All
I need to order main bearings for my 57 235.
I think my terminology from my side is different as on your side, so please bear with me
I have determined the following that they are 0.010 undersized dowel type.
where can I order these??
Please take note that I'm in southern Africa.
I need parts on 97 K2500 as well?
thank you in advance.
C Loubser
43 Ford CMP 4x4
48 Ford F1
41 CCKW 2 1/2 ton GMC 6x6
57 Land Rover series 1
59 Mercedes 220s
CHEVNAM #956520 07/15/2013 10:54 AM
CHEVNAM,
You might want to post the engine serial number pressed into the block in the ledge to the rear of the distributor (and the block casting code and block-date casting code). Here are various code locations.
These should ID the model/year of block.
There are a variety of sources for engine parts. Rockauto,com 1957 235 main bearings
1997 K2500 pickup
Just to clarify.
Up to mid 1955 main bearings had dowel upper and lower insert mains.
Starting in late 55 they went to tang upper and dowel lower.
If you just ask for dowel bearings you may get the wrong set.
You should verify what your engine uses.
My Blog
Wow! Where else would some one know when and if the main bearings were changed? Thanks! There is some good information here and I am glad to see it. Freely offered and kindly stated. Nice!
Steve
Steve H
thumbs_up
My Blog
