7 members (baldeagle, Hush, mick53, Southerntruck, SmalltownTRKGuy, Hotrod Lincoln, Gray_Ghost),
102
15
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 9 New Guy | | New Guy Joined: Jun 2009 Posts: 9 | Hi All
I need to order main bearings for my 57 235.
I think my terminology from my side is different as on your side, so please bear with me
I have determined the following that they are 0.010 undersized dowel type.
where can I order these??
Please take note that I'm in southern Africa.
I need parts on 97 K2500 as well?
thank you in advance.
C Loubser
43 Ford CMP 4x4 48 Ford F1 41 CCKW 2 1/2 ton GMC 6x6 57 Land Rover series 1 59 Mercedes 220s
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | CHEVNAM, You might want to post the engine serial number pressed into the block in the ledge to the rear of the distributor (and the block casting code and block-date casting code). Here are various code locations. These should ID the model/year of block. There are a variety of sources for engine parts. Rockauto,com 1957 235 main bearings 1997 K2500 pickup | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I need to order main bearings for my 57 235. I have determined the following that they are 0.010 undersized dowel type. Just to clarify. Up to mid 1955 main bearings had dowel upper and lower insert mains. Starting in late 55 they went to tang upper and dowel lower. If you just ask for dowel bearings you may get the wrong set. You should verify what your engine uses.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Wow! Where else would some one know when and if the main bearings were changed? Thanks! There is some good information here and I am glad to see it. Freely offered and kindly stated. Nice! Steve
Steve H
