5 members (Gdads51, SmalltownTRKGuy, 52Carl, Cosmo, 55shaker), 62 guests, and 0 robots.
Topics128,049
Posts1,055,629
Junior Member
Junior Member
I'm putting a sbc(350) in my 59 3600 and I picked up a 63 thru 66 V8 bellhousing but the junkyard didn't have a starter. Are they hard to find? the bellhousng has three holes(two are threaded) so I assume that the starter bolts to the bellhousing. Any help would be greatly appreciated.
John Carson City,NV
Riding in the Passing Lane
It shouldn,t be too hard to find. They were used from 55-72 on v-8s & longer on the big trucks. One hole is treaded & the bolt comes in from the back. The other two the bolts go through the housing. Check them out closely as often there are chunks broken off around the boltholes. If you get the drive end housing you can use the parts off latter model starters. The best one has 2 wires comeing out of the starter & an extension between the wires & selenoid. If you wan,t to spend the bucks you could order a reman from a parts store.
1972 Chevy c10 Cheyenne Super
If the parts stores don't have a starter for you,I have an extra one.Let me know. I'm up in Elko.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
