0 members (),
47
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95676 05/22/2006 4:23 AM | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | I'm putting a sbc(350) in my 59 3600 and I picked up a 63 thru 66 V8 bellhousing but the junkyard didn't have a starter. Are they hard to find? the bellhousng has three holes(two are threaded) so I assume that the starter bolts to the bellhousing. Any help would be greatly appreciated.
John Carson City,NV | | |
#95677 05/22/2006 2:03 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It shouldn,t be too hard to find. They were used from 55-72 on v-8s & longer on the big trucks. One hole is treaded & the bolt comes in from the back. The other two the bolts go through the housing. Check them out closely as often there are chunks broken off around the boltholes. If you get the drive end housing you can use the parts off latter model starters. The best one has 2 wires comeing out of the starter & an extension between the wires & selenoid. If you wan,t to spend the bucks you could order a reman from a parts store. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95678 05/23/2006 7:22 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | If the parts stores don't have a starter for you,I have an extra one.Let me know. I'm up in Elko. Speed | | |
