| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Great thread... In todays market the pool of buyers for a resto-rodded truck increases daily, while the appeal of bone stock original trucks declines every day as more and more of us older fellas pass on. It's been my ex[erience that only the ultra original survivors, the high end stock restorations or the totally modified touring trucks (modern drivelines) bring the high dollars. But it's all good, just depends on what trips YOUR trigger. If your plan calls for freeway driving at speeds of 65 mph then you'll need to modify the truck. On the other hand if it is a backroad 55 mph truck then you could very easily stick with a bone stock truck.Your call.  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | John is right...what ever trips your trigger but I almost consider it a sin to ruin a GOOD original. I've never had anything decent to work with so I used what I had on hand......however, if I ever find the GOOD original then I'd like to keep it that way.... | | |
