Motor mounts are different, fuel pump location, water pump height, length, valve cover height, harmonic damper length and diameter, plus lots of other pieces are all different. Can it be, sure if you can adapt and fabricate. Bell housings can be had to hook late model engine to early transmissions and still have the correct mounting points.
Joe
