3 members (gswbbc, Rusty Shackleford, Gdads51), 102 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#956267 07/14/2013 7:42 AM
I removed the speedo gear behind the speedometer because it was jammed completely and ate speedo cables for breakfast. The vacuum hose is plugged in the cab and the speedo cable mounts directly to the speedometer without the vacuumgear in between.
Can someone help me to think here. Even though the vacuum speedo gear is not there the speedo needle DROPS in speed when I go into high gear mode, how the heck can that be ?!?!? If I go low 4 and it shows , let's say 40 mph and go inte high it drops to 30 !?!?!
Of course I am missing something here, but I thought all the high /low gear did was with vacuum to change the rear axle ratio, nothing in the gearbox, right ?
Confused
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
Riding in the Passing Lane
The gearbox in the cable changes the speedo speed when you shift the 2 speed rear end. When rear end ratios change the speedo is not right. This gear box compensates for it.
1972 Chevy c10 Cheyenne Super
3B Offline
Hy lastchancetowing, when you shift the rear axle from low range to high range the driveshaft turns at lower rpm to maintain the same speed you were doing in low range, hence without the ratio adapter the speedometer will read slower, reflecting the lower driveshaft rpm in high range, hope that helps.
Thanks 3B, that explains it. Easy as hell smile
The vacuum part is okay and works fine. It was just messy and stuck. Have it running freely now, so I will just put it back in again and see if it works fine then.
[email protected]
Also:
Hey,Ulf! Off topic,but how did the exhaust manifold work out? Glad you posted this,because I have a plugged vacuum line,(under the dash), in my truck,too! I couldn't think of where the thing went,since it has electric wipers. Never even thought about the 2-speed! My speedo. doesn't work. I "gauge",by the "lines" on the road. Too many years driving over-the-road,I guess. I would still like to get mine fixed,but have no idea who may have working parts for the T.F. 2-tons. Nice to "hear" from you,again! Take care!
Mo' Tater
