1 members (Eisenholtz),
59
Mod | | | Forums66 Topics128,022 Posts1,055,377 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95602 05/15/2006 10:44 PM | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | My head lights quit working on my 51 1300. Today I removed the carb and the speedometer . I am almost positive that I didn't shake anything loose. I put new bulbs in the speedometer. My high beam light worked before. The head lights are ok I tested them on a battery but no power is going to the plugs. The tail lights are working. Are there any other fuses in the truck ? The light switch is really hard to get at so I am trying to find a mirror so i can look up in there. Any advice would be appreciated thanks. | | |
#95603 05/15/2006 11:26 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check your dimmer switch. Thats generally where the problem is. If there is no curent to the dimmer switch than it,s probably the light switch. I don,t believe there is a fuse for that. There are 2 fuses under the hood on the firewall. I think they are thge tail & stop lights. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95604 05/16/2006 1:01 AM | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Thanks mr . wrenchbender ret. it was the switch .the head lights are working now but the instrument lights are not working so I guess I'll look for a new switch.Thanks again for the quick reply. | | |
#95605 05/16/2006 2:17 AM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Thats a pretty standard high beam switch- I had one in several 70's cars and maybe even an 80s car- You can probably get one at any FLAPS.
#95606 05/19/2006 7:01 PM | Joined: Dec 2002 Posts: 3,438 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,438 | Check that your grounds are good too..
