4 members (2-Ton, baldeagle, BC59, 1 invisible), 74 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,420
#95602 05/15/2006 10:44 PM
My head lights quit working on my 51 1300. Today I removed the carb and the speedometer . I am almost positive that I didn't shake anything loose. I put new bulbs in the speedometer. My high beam light worked before. The head lights are ok I tested them on a battery but no power is going to the plugs. The tail lights are working. Are there any other fuses in the truck ?
The light switch is really hard to get at so I am trying to find a mirror so i can look up in there. Any advice would be appreciated thanks.
#95603 05/15/2006 11:26 PM
Riding in the Passing Lane
Check your dimmer switch. Thats generally where the problem is. If there is no curent to the dimmer switch than it,s probably the light switch. I don,t believe there is a fuse for that. There are 2 fuses under the hood on the firewall. I think they are thge tail & stop lights.
1972 Chevy c10 Cheyenne Super
#95604 05/16/2006 1:01 AM
Thanks mr . wrenchbender ret.
it was the switch .the head lights are working now but the instrument lights are not working so I guess I'll look for a new switch.Thanks again for the quick reply.
#95605 05/16/2006 2:17 AM
Thats a pretty standard high beam switch- I had one in several 70's cars and maybe even an 80s car- You can probably get one at any FLAPS.
#95606 05/19/2006 7:01 PM
Check that your grounds are good too..
Another quality post.
Real Trucks Rattle
