Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 146 guests, and 3 robots.
Topics128,290
Posts1,058,565
Members48,492
Hi,
Took over a 19540 Chevy 3800 1-ton dually from original owners. Was a daily driver on their horse ranch. it was fired up everyday 2x a day for ranch work no problems. folks sold the ranch and it sat idle for 2 years.
Question: where these originally a 12v system? appears that old battery is 12v, looks like a alternator is installed.
Anything else to check?
What battery size should work for this?
Boom
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
1954 Chevrolet trucks were all 6v systems.
An alternator is an indicator that changes have been made, most likely to 12v, but there is very small chance it is a 6v alternator.
If the battery has 3 cells (caps), it is 6v; if it has 6 cells (caps), it is 12v. 8v batteries were a rare "upgrade".
Post a few of the light bulb numbers and they can be identified as 12v or 6v.
6 volt from the factory,,if changed to 12 someone has done it,,size??naything that will fit in batt comp...doc
Group sizes 35 and 80 (75/35 universal fit) should be O.K.
Bill Burmeister
