4 members (Slick Willy, Otto Skorzeny, 1955 1 Series, Rexville48), 66 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#955510 07/09/2013 10:00 PM
A friend just installed a Pertronix "Flame-Thrower", (with coil),on a '59 Viking 60 bus. Before the installation,the vacuum-advance operated properly. Now,we have to move the distributor by hand,in order to start the bus. It also has a problem idling. Even when warmed-up,as soon as we try to open the choke,the engine "dies",and has a difficult time starting again. We did not set the plug gap,(yet).We also removed the ballast resistor,(per instructions).Were we supposed to keep this installed on the truck? Any suggestions would be appreciated. THANKS!!
Mo' Tater
Almost the same answers as in the other thread (it was a good idea to move your questions to a new thread):
The vacuum advance is mechanical and should not be affected by the installation of the Pertronix unit.
There is no need for a ballast voltage reducer in a 12v Pertronix system, if you are using the correct coil. The Pertronix flamethrower should be the correct coil.
Did you re-time the distributor to the Pertronix unit?
the vacuum advance may have picked that particular point in it's life to cash in, check it - there is also an internal mechanical [centrifugal] advance that may have gotten jiggered when you were working on the distributor
I don't know if he re-timed the distributor,or not. I think he was trying to let it warm-up,first,bit it wouldn't idle with the choke open-even a little! I'll have to ask him tomorrow. We're going back out there,to troubleshoot the distributor,as well as bleed the brakes,and /maybe give it the first drive,since it was parked in'74!! We have our fingers braided!
Mo' Tater
were is a good place to buy a pertronix for a 235/261 six, 12volt?
I ordered mine directly from them a few years ago,
...link...
1 909-599-5955
I called and gave them the serial number off the delco distributor and my voltage/ engine.
I think orielys auto can get them for you now
If you know the part number (probably something like 1168LS or 1168LSN12 for later distributor and 12v negative ground), they are readily available on eBay and from many vendors for around $80-$90 shipped and no tax).
Make sure you have the appropriate coil (relative to the use/need for a ballast resistor).
Riding in the Passing Lane
Sounds like you are 1 tooth off in putting in the dist. The timing is too slow.
1972 Chevy c10 Cheyenne Super
thanks for the responses. Was very helpful! John
