Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (tclederman, Peggy M, Woogeroo, klhansen, J Lucas, 1 invisible), 55 guests, and 7 robots.
Topics128,010
Posts1,055,299
Members48,419
#9550 09/29/2002 3:17 PM
good morning
Just got my engine (235) back from machine shop.
All in pieces.
When I brought the engine to shop the pistons , crank shaft and cam shaft where installed.
Now all came in a box and when I tried to install the cam shaft and match to crankshaft, I cant find the marks on the fiber gear.
The only two marks I could see are the logo and on the oposit side two faint 00.
How can I get the correct setting to have the timing where it should be.
Don't forget I am a novice and need simple explanations.
This project is my first frame up restauration.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#9551 09/29/2002 5:16 PM
Just a suggestion,,, I would have that fibered gear changed to an aluminum one.The fibered one is not as durable as the aluminum one and just will not last as long. smile
#9552 09/29/2002 7:30 PM
I will second the advice from Mechanic. I had the experience of having the fiber gear let me down and I was not amused.
1951 1 Ton Completed
#9553 09/29/2002 9:44 PM
I recently did a rescue job on a '39 truck ,, the owner was driving to Auckland ( 1000km away) he got 180km in the middle of the night and the engine stopped !! , sounded like running out of fuel ,, only the valves weren't going up and down !
Yep , no teeth on the fibre cam gear ,, this engine had had big $$$ spent on it too ..
wink
#9554 09/30/2002 6:29 PM
The difference between the car and truck 235 is the gear. Cars used fiber, it was quieter (especially after it broke) and the trucks used aluminum, a little noisier but far stronger. I have to admit, I have never seen a 235 with a broken aluminum gear. grin
Fred
52 3600
69 C-10
#9555 10/01/2002 2:43 AM
Thanks guys, I got the message. I ordered both new gears Cam shaft and Crank shaft. Crank shaft gear looked a little damaged from some body trying to pull the balancer .
Fritz Peyerl
