4 members (mick53, 1955 1 Series, klhansen, Shade Baby), 101 guests, and 1 robot.
Topics128,113
Posts1,056,277
Members48,439
need help prior to removing my huck rear brakes. Will 1953 3100 bendix style bolt to my 1950 huck axle. Lots of work so I really would like to know they will fit prior to getting started.
The backing plate would be different. I'm think it is riveted to rear axle flange..... Once you change the backing plate the rest should fit then..... Bendix used different wheel cylinders than the Huck did. the Bendix should give you better braking. They are self energizing brakes, the Huck brakes were not. You should change both front and rear to be the same.
The mounting flange that the backing plates are riveted to are in a different position. It's a no go. Easier to change to a Bendix housing.
My Blog
