| | | Forums66 Topics128,078 Posts1,055,935 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95540 04/29/2006 11:58 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I bought Langdon's mini HEI set up with the external coil and today was working on the wiring harness etx... and have a question- somewhere along the way the two wires from the four-prong ingnition module got disconnected from the plug that attaches to the coil and I want to be sure I've got it hooked up right before I put juice to it and possibly fry the ignition module-
Looking at the coil it has the coil wire to cap terminal closest to me and then four spade terminals at the top, 2 x 2.
I belive the red wire from the module goes to the bottom right, the wire from the ignition switch goes to the top right and the brown/black (negative) wire from the ignition module goes to the bottom left terminal. Then the top left terminal is for a tach.
Is that right?
#95541 05/01/2006 12:45 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I have a pretty good photo of my mini hei I can send. Just send me an email I'll get it off to you. Better yet, if you can send me a photo them I'm sure what you are refering to. | | |
#95542 05/01/2006 2:45 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#95543 05/01/2006 5:53 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I was planning on calling Tom today after searching the internet all weekend and not coming up with a diagram that would be helpful=
I did find lots of info on aftermarket 4 wire HEI ignition modules, like the one in the mini-hei, but they are to improve RPM's above 4,000, which is close to the limit on the old 261 and would be a waste of money.
JiMerit- I appreciate the offer of help. If I can't get in touch with Tom Langdon I'll take you up on it.
#95544 05/02/2006 2:02 AM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Tom said that the red wire goes to the right of the number cast into the plug, which is on the right if the external coil positioned with the coil wire closest to you and the four spades furthest away.
