| | | Forums66 Topics128,049 Posts1,055,747 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hi all - had a question that I can't find the answer to in my maintenance manual or on-line so far. I'm getting close to having my '37 gmc 1/2 ton back up and running after a rebuild. The fuel line that was on there was not original and I was wondering what the original config was - it should be close to the same (other than the routing) in the 37 chevy.
Prior to rebuild it had a hard line from the tank stopcock which was routed to the frame, then a short (4'') segment of rubber tubing to the fuel pump fastened with clamps to the line and pump.
From parts available on jim carter, I've surmised that there was originally a short rubber tubing off the stopcock and then a hardline to the fuel pump. was there a hose from the hardline to the fuel pump as well? It seems like you would want a flex there as well as there is movement between the frame and the engine as well as the tank and frame.
Thanks to anyone who can help! | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | My 36 GMC has a short rubber line to the fuel pump. I can send pictures if that helps. | | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | That would be really helpful! Thanks dunfire. | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | pm your email to me and I will get the pictures out to you.
