1 members (1955 1 Series),
75
Mod | | | Forums66 Topics128,062 Posts1,055,857 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 173 Shop Shark | | Shop Shark Joined: May 2013 Posts: 173 | I have a 216 engine (don't know what its from) that has some unusual marking on the side of the block. Casted on the side is the number 48 in the center of a circle. The casting is lifted and is about he size of a half dollar? Has anyone seen one of these before and if so what is it?
I own several pre-war 216's but the "48" marking is very unique and interesting.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Both 1948 and 1949 has the raised 48 in a 2" circle. You would need to look at the casting date behind the starter to see exactly the month, day, and year.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2013 Posts: 173 Shop Shark | | Shop Shark Joined: May 2013 Posts: 173 | Any major improvements/differences in this engine from earlier models? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There were a few starting in 48. Rods got narrower and used thinner Babbitt. Mains went to precision inserts. Block water drain went from 1/8" to 1/4" pipe thread. There are more but that is off the top of my head.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2013 Posts: 173 Shop Shark | | Shop Shark Joined: May 2013 Posts: 173 | any chance it could be a 235? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You would need to check the code stamped next to the distributor or measure the height of the block. 235's are 1/8" taller than 216's.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Dave, Would that 1/8 inch difference between 235 and 216 be from the "Pan ledge to top of block ? Do you know by chance what the 216 measurement is or the 235 measurement is? Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 216 is 10 3/4" from pan ledge to deck of block. 235 is 10 7/8".
