8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 56 | I have '59 Apache that I'm restoring. The wiper motor is electric. I want to replace it with a modern electric motor. All that I've found say I must have the old style vacuum wiper arms and transmission that I don't have. Is there a conversion for the stock electric wiper moter? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It's confuseing. I just put one on my 56 to replace the vacuum wipers. The catalog listed it for that purpose but the box said for replace ment of an original electric motor. I was skeptical but it fit perfect. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 58/9 wipers and trans/arms are different than the 55.2-57 [vacuum as well as electric], AFAIK there are no modern replacement motors that are specific to 58/9 that had original electric wipers, but you should be able to find the vacuum arm parts via the parts wanted here, or maybe from a vendor like Jim Carter who has a fair stock of used parts available, might give them a call Bill | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | http://www.pacificwesterndesign.com/RainGear/index.htmSays no drilling uses stock mount points. I think all the other stuff needed is repoped.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
