6 members (FishinToms53, klhansen, Hanks custodian, Mike Roache, ShopRag, Stovebolt48), 103 guests, and 0 robots.
Topics128,049
Posts1,055,634
#95494 04/28/2006 2:21 AM
A recent powersurge blew out all my lights.One new one works the other doesnt.I asume the 2 terminals opisite one another are high and low?and the bottom one ground?On high i asume i should have curent to 2 terminals?If the above is corect then i shouldnt have curent at all three on high as i do now,didnt check low.Im geussing ive got a hot wire and ground makeing contact?
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#95495 04/28/2006 4:17 AM
Actually, the ground is the right side of the "U" as you are looking at the back of the bulb.
The bottom is the low beams, and the left is the high beams.
For more information, Click Here
#95496 04/28/2006 4:26 AM
1 Offline
you will get curint if u use youre com (ground) and your hot but you will probibly blow the fuse in your neater what you should d0 is look fore volts.
#95497 05/01/2006 3:23 PM
I was checking my dimmer switch just the other day and determined that as I switched it back and forth I would get continuity from the power in terminal to only one power out terminal at a time. This leads me to believe that on low beam one wire is hot and on high beam the other wire is hot. Not both at the same tine.
See Oehm Jr's 46 answer to "More on Headlight Wires" Topic. He has a nice diagram of the headlight plug
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#95498 05/02/2006 12:14 AM
fusable links will help
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001675#000005
http://www.madelectrical.com/electricaltech/onewire-threewire.shtml
Jim & Caroline
#95499 05/02/2006 10:54 PM
Riding in the Passing Lane
You are correct on the dimmer switch test.
1972 Chevy c10 Cheyenne Super
