0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#954826 07/06/2013 8:03 PM
I have found that my TH350C transmission mated to the 350SBC in my '57 is leaking oil through a 4 pin connector on the driver side of the tranmssion. Here is a link to the part: http://www.rowand.net/Shop/Tech/images/TH700R4WiringConnectors17.jpg
Any clues on how to repair or replace? It is a plastic piece and I dont want to just yank and break something off...
Thanks!
You drop the pan, and there is a clip release on the inside part of the plug. When you pull it out there is an o-ring around the plastic piece.
Thanks.... next question, is this a readily available part and what is it called?
