2 members (baldeagle, TPR57C),
62
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | I have found that my TH350C transmission mated to the 350SBC in my '57 is leaking oil through a 4 pin connector on the driver side of the tranmssion. Here is a link to the part: http://www.rowand.net/Shop/Tech/images/TH700R4WiringConnectors17.jpgAny clues on how to repair or replace? It is a plastic piece and I dont want to just yank and break something off... Thanks! | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You drop the pan, and there is a clip release on the inside part of the plug. When you pull it out there is an o-ring around the plastic piece.
| | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Thanks.... next question, is this a readily available part and what is it called? | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | | | |
