| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 52 | I have a 1965 C10 Fleetside that I have taken all the way down to the frame. I am in the process of rebuilding the front suspension and I am starting to wonder if I have gone too far. I removed the upper and lower control arms (a-arms) and have replaced the upper control arm shaft. I have removed the lower control arm shaft and I am attempting install a new shaft with little success. When I try and tighten the control arm bushings it is bending the control arm rather than threading into the control arm. Are there any special tricks to installing new shafts? Is there any special tools required? Any help or advice would be appreciated. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bargy1, you may want to send a pm to a bolter here name lugnutz. He finished up the frontend on his 62,or 63, just a short time ago. I think the years are the same and if they are I'm sure he can walk you through any problems.....IF Someone else doen't chip in soon. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Hey there, its me, Lugnutz. Sorry, but I did not replace the control arm shafts or bushings, so I don't really have any advice to offer. Wish I did. | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Bargy1,
I did mine a couple of years ago but don't remember having the problem you seem to be having. I went through my pictures but couldn't find anything helpful for you. Do you have the 1963 Chevrolet Truck Shop Manual? That will be extremely helpful.
Here's what is says:
Lower control Arm Assembly Removal 1. Raise vehicle and remove spring as outlined under Spring-Removal. 2. Disconnect control arm from crossmenber by removing four nuts and bolts securing cross-shaft.
Repairs Bushings 1. Remove grease fittings from bushing outer ends and unscrew bushings from control arm and shaft. (fig 22). 2. Slide new seal on each end of shaft and insert shaft into control arm. 3. Start new bushings on shaft and into control arm. Adjust shat until it is centered in control arm, then turn bushings in and torque (200-220 lb. ft. if spacer is used, 125-140 lb. ft. if no spacer is used). Figure 23 shows the final positioning of the shaft. check shaft for free rotation and install grease fittings.
Sorry I can't post the figures.
I did not use any special tools. Give Tony from 4-5-6 Chevy Trucks a shout. I bet he's done a million of these.
Tom
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Dec 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 52 | Tom, I do have the manual and followed the instructions but I am still having trouble. The bushings are threaded on the inside to screw on the shaft and have threads (more like ridges) on the outside to screw into the control arm. When I try to tighten the bushings with one person on each side it threads onto the shaft but doesn't thread into the control arm - it just wants to bend the arm. I'll try Tony and see if he has any advice.
Thank you for the responses. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hit me with a call or PM and I will help you out with the process. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I know we had the same problems with offshore LCA shafts on a buddy's ride, went to MOOG brand parts and they went together fine. | | |
