2 members (NJC, baldeagle),
33
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | My truck is a 1953 half ton, converted to 12v. My ammeter always points to "charging" but fluctuates up and down a bit. Today while waiting at a traffic light (low idle) with the left blinker on, I noticed the ammeter needle pulsating with the signal lights. Not sure if I should be concerned or not, I've never had any generator or battery problems. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | That's normal. The blinkers suck more amps than the generator puts out at idle. The ammeter probably shows a slight discharge at idle even with the turn signals off.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | Agree with Lonnie, seen it many times, even at higher RPM you will see it wiggle but maybe always stay in the charging side.
