1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
#953061 06/27/2013 4:55 PM
I've been following advice on this site regarding the driveline for my '42 1/2T.
I found a reared from an 87 S-10 4x4 with 3:73 gears. However, I thought this rear was a bolt in but the pads on the rearend don't match up with the rear springs on my truck. I know I'm missing something here. Appreciate any advice.
I have never tried to install one. But if for sure the pads are not correct, then you will have to remove them and reweld in the correct position, with attention to proper pinion angle.
I've seen new pads offered at the truck parts places.
You need to cut the pads on the rearend off and get a set of pads for the narrow springs like you have on the '42. You can buy these from a number of different suppliers. Be sure to check and set your pinion angle correctly so you won't have any driveline vibration issues.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
Hate to sound stupid but I've never done this before. How do I check and set pinion angle correctly? Do I have to have the engine ,transmission, and drive shaft all installed to do this? Thanks
It is not that difficult. If you look in the Tech Tips section there is an article on setting up the driveline.
you need to change the spring perches jc whitney sells the 1 3/4 spring perches you need to install that rear, I have a s-10 rear in my 46 1/2ton and I used the jc whitney perches,also, you need to get the s-10 plates for the bottom of the springs because they have the lower shock mounts on them, you'll also have to redrill them and get new u bolts, i have pics of my install ..click on the link below
