4 members (Robert Crandall, J Lucas, 1955 1 Series, Otto Skorzeny), 99 guests, and 2 robots.
Topics128,094
Posts1,056,465
Members48,443
#953959 07/02/2013 5:29 AM
Curious what everyone is using for rear end ratios? Since the old under powered trucks had to make it up with low gears. Problem is that makes em pretty slow on the freeways. Has anyone upgraded the axles or can you still get ring and pinions for the larger trucks?
the ashton is a 8.81 low range and a 6.33 in hi
i dont know what the dump is but its close to the ashton.
the 40 is a 4.56
Quote
i can exceed what the lowest speed is by law. i run the majors every chance i get. if they want to run up my [censored] then they'll know what gear i got as they're pulling my gears out of thier teeth grin
My Fire Engine has an Eaton 2-speed with 6.14/8.36 gears and will run low 60's all day long. I have 11.00 x 22.5 tires and it's powered by the 322 V8 with a 4k rpm governor.
My tow truck has the GM 2-speed with 6.40/8.72 gears and will run 65 mph. It has 10.00 x 22.5 tires, it's powered by a 350 sbc without a governor.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
What kind of RPM are you running Mike. On my firetruck and I assume its geared same as yours at 2500 rpm I am about 50 miles per hour.
The gears in my truck are not stock to 1957...I swapped them in when I got the truck and I have no idea what they were in originally. The junk yard had lots of truck third members hanging on a rack and I found this one that fit my rear housing making it an easy swap.
I'm turning about 3500 rpm at 65 mph. If I push it to 70 I start bouncing off the governor which is set at 4000 rpm.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
