6 members (2-Ton, delwrench, 1955 1 Series, UtahYork, Otto Skorzeny, dt235sd), 86 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
#953780 07/01/2013 11:56 AM
I got my block back from the machine shop and I've started putting things back together. THere is a brass tube that runs through the block, does someone know what this tube is? I plan to replace it but don't know what "it" is.
Thanks, Kevin
Here is a link to a set of slides explaining how to change one out. The years are a bit off but the concepts are the same.
http://www.flickr.com/photos/advance-design_parts_co/8370900481/in/set-72157632499960078
thanks Brad, this will help a lot!!
Just changed mine recently. Not too hard.
http://www.fiftee6.com/fiftee3.7/ good luck! Take your time...
Phil
