| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | Just got the 63 C-10 panel truck on the road last week . Starts and runs fine now that it is getting used more . I am finding that going downhill or decelerating I can feel and hear the engine stumbling a bit . Would the carb be the first place to look for the cause of this? Everything under the hood is original . Had it out for a two and a half hour trip this week ,used $25 worth of gas to go that far. From the tail pipe colour it is running rich , but thats only a guess. Thanks Murray
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would start by checking the timing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | $25.00 worth of gas in Canada, isn't very much fuel, and you drove 2 1/2 hours on it.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You may also want to check the vacuum advance.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | Start with the basic, timing, vacuum hoses, vacuum advance, be sure they are set and working. Make sure the mechanical advance is free and working.
I would rebuild the carb just for piece of mind. The kits can be had at any local parts house (around here anyway) and the carb is one of the easiest to rebuild. Clean it three or four times using small copper wire to clean the ports. If its not clean, you wasted your time.
You should see 12 to 14 ( US ) miles per gallon, I wouldn't expect more then that. With a clean carb, it wouldn't hurt to add fresh spark plugs. This would also be a good time to check the points, plug wires, and condensor.
Joe | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | I have adjusted the timing , seems better now . I also leaned out the fuel mixture . Wife drove it before that and it was missing under hard (her normal) acceleration . I did just look at the vacuum advance as I had to replace it on the 54 . Iv'e got an hei unit sitting in a box for this motor , better get to it. Thanks | | |
