4 members (Phak1, texczech, Shade Baby, WICruiser), 88 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
#953580 06/30/2013 8:21 AM
Just got the 63 C-10 panel truck on the road last week . Starts and runs fine now that it is getting used more . I am finding that going downhill or decelerating I can feel and hear the engine stumbling a bit . Would the carb be the first place to look for the cause of this? Everything under the hood is original .
Had it out for a two and a half hour trip this week ,used $25 worth of gas to go that far.
From the tail pipe colour it is running rich , but thats only a guess. Thanks Murray
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
Hydra1/2ton #953596 06/30/2013 10:40 AM
I would start by checking the timing.
My Blog
Hydra1/2ton #953597 06/30/2013 10:51 AM
$25.00 worth of gas in Canada, isn't very much fuel, and you drove 2 1/2 hours on it.
Brian
1955.2 3100 Truck
Hydra1/2ton #953628 06/30/2013 3:49 PM
You may also want to check the vacuum advance.
My Blog
Hydra1/2ton #953752 07/01/2013 8:55 AM
Start with the basic, timing, vacuum hoses, vacuum advance, be sure they are set and working. Make sure the mechanical advance is free and working.
I would rebuild the carb just for piece of mind. The kits can be had at any local parts house (around here anyway) and the carb is one of the easiest to rebuild. Clean it three or four times using small copper wire to clean the ports. If its not clean, you wasted your time.
You should see 12 to 14 ( US ) miles per gallon, I wouldn't expect more then that. With a clean carb, it wouldn't hurt to add fresh spark plugs. This would also be a good time to check the points, plug wires, and condensor.
Joe
Hydra1/2ton #954536 07/04/2013 11:18 PM
I have adjusted the timing , seems better now . I also leaned out the fuel mixture . Wife drove it before that and it was missing under hard (her normal) acceleration . I did just look at the vacuum advance as I had to replace it on the 54 . Iv'e got an hei unit sitting in a box for this motor , better get to it.
