WHY ?????
YES the HOT 12V and high amperage is present in the cab all the time. CAP those posts on the back of the amp gauge for safety !!!!!
First a 12v ampmeter doesn't run the 6v one and may cause you problems. Running a resistor is not the way to handle that.
Note:: NOT all alternators run three wires, you can get them w/ only one wire. There are reasons for having both. Me, I like the three wire better. There are different ways to wire each. If you have a three wire, it is a good idea to run an idiot lamp in the cab dash.
The BIG FATTY wire usually comes from the batt +12v post or you can run it directly off the starter +12v post to the ampmeter plus side. The ampmeter neg side BIG FATTY wire goes to the key switch...........
Ampmeters are a good way to monitor the voltage system while the engine and any electrical systems are in use. You have to wire the ampmeter w/ a BIG wire, both 'in' and 'out' (to the key switch. Everything electrical MUST run thru the ampmeter, so the operator can see the charge rate. This means depending on your electrical accessories and the way in which you have them wired, your key 'out to accessories' should go to a fuse panel, then to the accessory. If you run lots of accessories (or plan to), having that kind of amperage inside the cab of the truck is old school thinking. It is somewhat unsafe to the modern way of wiring w/ relays. Relays allow the 'big' wires close to where they should be located, thus giving those accessories the full power for functional operation. Smaller wires trigger the relay (on- off) from the remote truck cab.
((( Running EVERYTHING thru one wire to ALL your electrical compoments is not really the safe way, The ampmeter way.)))
http://alanhorvath.com/54chevy/mad_electrical.php one and three wire alternators:
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001849#000000
http://www.tr6web.com/Documents/tr6/meters.html http://pweb.jps.net/~snowbum/amp&voltmeters.htm
Dispite where this info comes from... apply it to stovebolts cause it's all the same. 12-14 volts 'in and the rate of amps out'. The reference to airheads means an older BMW boxer motorcycle, but again the info is ALL the same and APPLIES to our situation. substitute stovebolt for airhead.
It looks like you have many responses to this question and for some reason you have your reasons why you want to cross back to the ampmeter.
my .02 and it's your truck not ours.
DO as you please.
