1 members (baldeagle), 43 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#952510 06/25/2013 11:54 AM
I have a 54 235 engine in my 46 truck and when it gets hot the engine turns over slowly and will start sometimes and other times will not. I have just replaced the starter. It starts fine when cold.
b51r
b51r
It could be a number of things but to small diameter battery cables is the most common problem.
My Blog
I have all large battery cables on it. It is also a 6 volt system
b51r
b51r
What's your timing set at? Sounds like you have too much timing.
My 46 GMC on Photobucket
Sir Searchalot
Sir Searchalot
Battery
x2 48gmc's suggestion.
I found that adding the vacuum gauge to my timing regime made a world of difference dance
probably because I found it hard to find 28* past the bb in my search for the dist. mech/vac/total advance blush
while trying to adjust for today's fuel...
Give me ambiguity
or give me something else
If you can demonstrate the problem at home, try powering the coil with a battery charger.
1951 1 Ton Completed
Sounds like a bad ground to me. I had the same thing with my '51 216. Found corrosion on frame to block ground strap. Cleaned it and problem was gone. Check all your grounds. This is a 6 volt system too.
Hope this helps.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
I am having a problem similar. Who said timing? My battery appears strong and the motor turns fine (when warm) but struggles to fire. Cold it fires right away. If timing - which direction. Advance it or other way? What is actually happening?
~ HB
1962 Chevrolet C10
1962 Suburban
retard timeing to start easier. Advance for better performance and fuel economy. ALL witin reason
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
A slow crank when hot is a voltage problem. You need 00 or 000 gauge cables with really good clean ends on a six volt system. Thats positive and ground. Make sure there is no paint under the terminals and use star washers for better contact. Check the voltage at starter when cranking slow,that will tell you a lot. Don't try to check amps with out a really good heavy meter!
Bypass the key switch with a wire straight from batt to coil when its hot. This will tell you if the wire harness is good. Checking voltage at the coil is good idea and can help diagnose the problem.
Joe
