BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
1 members (Movingeric),
487
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jan 2011 Posts: 237 'Bolter | 'Bolter Joined: Jan 2011 Posts: 237 | | | | | Joined: Apr 2010 Posts: 232 'Bolter | 'Bolter Joined: Apr 2010 Posts: 232 | "Mighty Mysterious"???But it's a free bump. | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 507 | Here is another link you can try: www.davesclp.com
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | Joined: Nov 2012 Posts: 543 Shop Shark | Shop Shark Joined: Nov 2012 Posts: 543 | Marilyn Monroe.... That would be worth some bux... I would suggest you ask the Ca DMV.
| | | | Joined: Jul 2004 Posts: 2,946 'Bolter | 'Bolter Joined: Jul 2004 Posts: 2,946 | Minneapolis Moline?  | | | | Joined: May 2001 Posts: 7,440 Extreme Gabster | Extreme Gabster Joined: May 2001 Posts: 7,440 | If we keep on with the shuckin' and jivin' this thread is going to Greasy Spoon. | | | | Joined: Oct 2004 Posts: 1,781 Master Gabster | Master Gabster Joined: Oct 2004 Posts: 1,781 | I will try and keep this on subject. I have not seen that designation in the many years of collecting license plates. I am no expert on these, especially the early years like yours. I have talked with Dave before on designations and he doesn't pay attention to them at all and may be of no help in identifying this plate. i will check some of my resources, but a couple of guesses might be:
METER MAINTENANCE (First parking meter was in 1935, so this might not work)
METER MAID (Doubtful that they used this and the plate looks like full size not Motorcycle plate)
MUNICIPAL MAINTENANCE * Street Sweepers - Road Crews etc.
| | | | Joined: Aug 2005 Posts: 6,383 Ex Hall Monitor | Ex Hall Monitor Joined: Aug 2005 Posts: 6,383 | When Kansas used that format on tags it was a county designation. For instance my home county of Cowley county was CL. These days it's still CL but put on a sticker in one corner rather than embossed on the tag. Here's one for Sedgwick county.
| | | | Joined: Jan 2011 Posts: 237 'Bolter | 'Bolter Joined: Jan 2011 Posts: 237 | | | | | Joined: Aug 2005 Posts: 6,383 Ex Hall Monitor | Ex Hall Monitor Joined: Aug 2005 Posts: 6,383 | Google is your friend (sometimes). Go to page 5.
| | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | good find Tiny, but not sure there would have been "modular mobile" [homes] in 1937  interesting they have specific categories for Chev and International 'burbs, but nothing specific to panel trucks!! that's the modern listing tho' and here they class panel trucks as 'vans' now Bill | | | | Joined: Apr 2005 Posts: 507 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 507 | These codes are used on paper work at the DMV to identify the type of vehicle and are not used on the license plates.
