2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Looks good, Dogface
If you have vacuum wipers, you could connect the vacuum hose from the intake manifold vacuum port to the wipers. The distributor advance line runs to the T and one rubber hose to each carb (for a balanced appearance).
We await the first start and run report.
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Thanks Tim.... I changed to elec wipers a month or so ago...
I can hardly wait to drive it and hear those duals purr with the metal/glass packs... I have also ordered parts to go to a 3.55 dif..
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | A neat looking installation. What model are the carbs? | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Holly-Weber two bbls. I bought the entire set up from Tim some time ago. He had gone from a 235 to a 261. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Carter-Webers from Tom Langdon Each was used on 1600cc Ford Pintos (Holley/Weber 740) Electric choke (works 6v and 12v) Progressive two barrels This is not the Holley-Weber 5200 and not the Weber 32/36 DGEV | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Thanks for the correction, Tim. A good and more specific explanation.  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Let's hope it starts up easily and runs smoothly, Mark  | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | It's already been run and he says its running smooth and much better than before. Once the pipes are on the headers I'll test drive it.
Still have a bad TO bearing to replace though, and broken speedo cable... | | |
