4 members (55shaker, DadsFirstPickup, JoergK., 1 invisible), 311 guests, and 1 robot.
Topics128,152
Posts1,057,011
Members48,460
Which is better and for what reason? I'm going to buy a dual set up and install it, but then ran across the option for a dual with power booster. Not sure if I'll need the power booster until after I start looking at disc brakes for the front.
Personally, I think if you are running an entirely stock driveline, the dual manual master cylinder is fine.
Drew
I upgraded to the dual set up in my truck but spent the few extra bucks for the booster combo also. If I ever upgrade to the disc set up then I only have to install a proportioning valve and walla. To each is there own and really in my humble opinion the important thing is the dual tanks on the master cylinder.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
It's stock for now. I'll add the booster and prop valve later. Thanks for the advice!
