0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
My guy got this done a few days ago. Exhaust pipes not yet on so can't drive it just yet. Seems to run very well...
http://s1276.photobucket.com/user/Dusty411/media/Intake2_zps540dd73a.jpg.html?sort=6&o=1
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Looks good, Dogface
If you have vacuum wipers, you could connect the vacuum hose from the intake manifold vacuum port to the wipers. The distributor advance line runs to the T and one rubber hose to each carb (for a balanced appearance).
We await the first start and run report.
Thanks Tim.... I changed to elec wipers a month or so ago...
I can hardly wait to drive it and hear those duals purr with the metal/glass packs... I have also ordered parts to go to a 3.55 dif..
Mark
1949 Chevy 1/2-Ton
Lucielle
A neat looking installation.
What model are the carbs?
Holly-Weber two bbls. I bought the entire set up from Tim some time ago. He had gone from a 235 to a 261.
Mark
1949 Chevy 1/2-Ton
Lucielle
Carter-Webers from Tom Langdon
Each was used on 1600cc Ford Pintos (Holley/Weber 740)
Electric choke (works 6v and 12v)
Progressive two barrels
This is not the Holley-Weber 5200 and not the Weber 32/36 DGEV
Thanks for the correction, Tim. A good and more specific explanation. wink
Mark
1949 Chevy 1/2-Ton
Lucielle
Let's hope it starts up easily and runs smoothly, Mark thumbs_up
It's already been run and he says its running smooth and much better than before. Once the pipes are on the headers I'll test drive it.
Still have a bad TO bearing to replace though, and broken speedo cable...
Mark
1949 Chevy 1/2-Ton
Lucielle
