0 members (), 150 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#953027 06/27/2013 2:08 PM
Good day everyone
I have an SM420 in my 54 3100. The transmission started popping out of 4th gear while climbing hills and sometimes during acceleration. In investigating why it would do this I found that it is a result of a worn out pilot bushing. I found that there was only a remnant of the pilot bushing left in the end of the crankshaft.
The input shaft on my SM420 has around a 1/8" up-and-down play on it. My question is: How much play on the input shaft of my transmission is too much? At this point I am trying to determine what is normal so I know whether I need to fix this or not.
Thanks in advance for any comments
Walt Williams
La Verkin, UT
Riding in the Passing Lane
A small amount of up & down play will be normal. Now would be a good time to pull the retainer & check the front brg. After you remove the retainer clean the brg. with brake clean or something. Shine a light on the brg. & slowly turn the shaft watching for any pits or scores on the balls & races. This brg is the first to go & can cause noises in the lower gears. It can be replaced without tearing down the trans.
1972 Chevy c10 Cheyenne Super
